4Gb Corsair XMS3... 15.v or 1.65v?
11 Oct 2010
will I have to change it? I was told I could just put in XMS3 and change speed to 1600Mhz without touching voltages...
It's advisible to set the voltage, timings and frequency manually - it's best practice. Or you can enable the XMP and just change the voltage.
also...will Corsair Vengeance Low Profile stick do? these have same timings and XMP
Don't know from personal use - but I would be surprised if it didn't run under 1.55V as most brands of DDR3 within that spec do - but you may need to consider the profile depending in your cooler.
they are 1.5v sticks
