My FTTC with Zen should go live tomorrow! (13/07/11 01:17hrs)
Has your ping in general changed since the first 10 days or just to that particular address?
Sorry, I was slightly sleep deprived. Yes, it went live today. I have Fibre Office Plus. Expensive but I won't settle for an inferior connection.
I've had an interesting time with my infinity order. I’m moving back to BT for both my landline calls and broadband from O2.
I got a phonecall from the infinity team the day after placing my order to say that they'd need to temporally cancel the infinity side of my order until the migration of my phone service is complete from O2 back to BT. They need the line to be in BT hands before they can process the infinity order further, they've set a flag to contact me on the 13th July to re-instate the infinity order.
My equipment order is still due for delivery on Friday and the infinity team were confident they'd be able to keep my original install date of next Tuesday. Guess I'll find out tomorrow!
 . I'm still wondering weither or not to use the HH3 or if I should switch to a Netgear WNDR3700?
. I'm still wondering weither or not to use the HH3 or if I should switch to a Netgear WNDR3700?whats seems so unreliable is the openreach modem. I guess we dont have an alternative for that ?
Only the later modems.
Mines been powered up 24/7 since last August and doesn't even get warm let alone hot.
Is it wall mounted?
My BT engineer is aware of the overheating issue. Apparently they're now using a new batch of VDSL2 modems.
Can you tell when I switched over?
Loving fastpath.
White openreach VDSL modems are exceptionally prone to failure in certain limited batches, but most just are heat touchy, they may last weeks or months only time will tell. ALWAYS wall mount (and not behind a freaking curtain rail )
