- 28 Mar 2005
- Newbury
not really its a HP Photosmart 1315, ok it is 'OLD' but it has GOOD printing Quality!
A thirty second google and I've found people using that printer on 64 bit windows 7 using alternate drivers. I'd bet the same would be true of the scanner if I could be bothered to look.
nand i find that 2 GB of RAM it still more than enough for any game out now and it will take many years untill they start making games then 'cannot' work on 2 GB so..
why do i need an 'upgrade'???
After a quick look at the front page of the Steam store, I can see plenty of games that list 2gb ram as minimum requirements, with plenty having more than that recommended. I would have thought very few people would be interested in trundling round at minimum spec due to an limitation that can easily and cheaply be overcome..
You say that it will take years until they can make games that can't work with just 2gb. I disagree, there's plenty of games that are pushing it at that already, particularly when you start modding them.
Seeing that you can get 4gb ram easily for under £25, I think you'd be mental to think 2gb is fine for a gaming machine these days.
