new card Advice
1 Jul 2011
i am getting a asus m5a88m mobo and a new video card, i have always had nvidia before but now i am not sure. i dont have a big budget so £90 for the video card. But since the the mobo has a hd4250 with crossfire support onboard is it worth getting a ati one- but i have no idea what one.
also i only have a cheap monitor with no dvi connectores just a vga and i see most video cards only have dvi connectors any way round this.
any ideas please.
Any card will come with a DVI -> VGA adapter, so no problem with that.
The motherboard you have says crossfire support, this is only a problem if you want to run 2 cards, then they both have to be AMD (and the same model). If you are only running 1 card then you are ok to choose AMD or Nvidia.
With a budget that low, it will probably be a AMD card.
What PSU do you have? as that can make a difference too.
as per Freakbro really need an idea of what psu you have.
otherwise i'd consider an ati 5770, or the 5830 (currently on offer for under you £90 budget), if you can stretch to £100 then have a look at the ocuk nvidia 460.
psu should be fine, how long you had it ?
edit:
looks like the mobo has Hybrid CrossFireX Support, so you'd match an ati card with the onboard, so need to go the ati 5770/5830 route rather than the nvidia 460 if you want to use it.
New , few weeks old part of my upgrade process. Had a cheapo 160w.
Can i use the onboard video and the dedicated video card in cross fire
Thanks
Thanks for the update, do i need any special cables fro the cross fire
can't see that a cable could be connected as the onboard gfx are usually just a chip.
as you mentioned it would be nice if manufacturers detailed there items better, but i guess they just can't be bothered most of the time.
