14 Jul 2011 at 15:06 #1 snadge snadge Associate Joined 11 Oct 2010 Posts 551 its for install in PC thanks
14 Jul 2011 at 15:13 #2 Gizmowithatt Gizmowithatt Associate Joined 25 Jul 2006 Posts 275 I have 2 and they did not
14 Jul 2011 at 15:19 #3 snadge snadge Associate OP Joined 11 Oct 2010 Posts 551 Gizmowithatt said: I have 2 and they did not Click to expand... ok thanks for that...
14 Jul 2011 at 15:19 #4 InfiniteNoise InfiniteNoise Associate Joined 3 Feb 2011 Posts 1,245 OCZ Vertex 2 60GB does, mine came with it at least. It's more of a bracket though, doesn't fit in every 3.5" slot without a bit of modding.
14 Jul 2011 at 15:20 #5 snadge snadge Associate OP Joined 11 Oct 2010 Posts 551 you are supposed to get them with Vertex 2E anyway
15 Jul 2011 at 07:02 #6 chameleon chameleon Associate Joined 31 Jul 2005 Posts 894 Location Edinburgh My vertex 3 is sitting in one. Bear in mind, they also fo a "Bigfoot" version of sone of their drives that are in a 3.5" chassis. Last edited: 15 Jul 2011
15 Jul 2011 at 14:49 #7 gazzaman2k gazzaman2k Associate Joined 18 Oct 2005 Posts 327 Location Leicester my 2 vertex 1's didnt come with them
15 Jul 2011 at 15:32 #8 setter setter Caporegime Joined 14 Dec 2005 Posts 28,067 Location armoy, n. ireland A friend bought a vertex 2e 120gb, it came with a bracket. Bought the 3.5" bigfoot version myself as i didnt want to use an adapter.
15 Jul 2011 at 19:43 #9 snadge snadge Associate OP Joined 11 Oct 2010 Posts 551 I have ordered a Vertex 2E and will tell you - its advertised as so on another site
16 Jul 2011 at 17:58 #10 seandog seandog Associate Joined 18 Jun 2011 Posts 385 Location Belfast I got an agility 3 60gb from OCUK 2 weeks ago and mine had no 3.5 converter
16 Jul 2011 at 18:03 #11 ots3go ots3go Associate Joined 15 Jan 2005 Posts 2,395 Location Leiden - NL Had a couple of Agility 3's (60GB), no converter. Last edited: 16 Jul 2011
16 Jul 2011 at 18:09 #12 snadge snadge Associate OP Joined 11 Oct 2010 Posts 551 yeah it came today and has the converter...thanks guys
16 Jul 2011 at 20:04 #13 seandog seandog Associate Joined 18 Jun 2011 Posts 385 Location Belfast lucky you good luck with the SSD its a great piece of kit
17 Jul 2011 at 15:20 #14 Mr. May Mr. May Soldato Joined 23 Apr 2009 Posts 3,473 Location Derby my 60gb vertex 2e did but my 120gb vertex 2 didnt
