Thanks for your help, really interested in it.
Only concern is that it looks quite thin, I'm 6"2 and 15.5 stone and will probably do a few jumps, the frame looks quite thin, but it could just be the images.
It will be fine. They are built to take quite a bit of punishment and don't forget the fork will absorb impact as well as your body (bended knees/arms etc) so the frame will hardly snap in two on small jumps. Trying 10-20ft drops and landing badly is another matter, though you're more likely to fold the wheels than snap the frame, but then you wouldn't buy a cheap XC hardtail for that anyway...
Edit: I'm easily 15+ stone with all my gear on and I never had any problems on my Carerra Kraken when I had one. Either that or the Rockrider will be fine, unless of course you are planning to do crazy stuff on it.
