Is dust getting trapped in the monitor going to be an issue with the bezel not being flush with the screen? I'd get the glass version, but unless I'm mistaken Hazro won't sell it directly, only through OCUK. Is that correct?
I think Hazro sell the glass version, and OCUK does the non glass, since the non glass is the modified one?
I haven't had anyone with a glass screen confirm this, but I think the bezel problem relates to the fact the screen was originally designed with the glass in mind. That glass is sealed, so no dust should get in and I believe the glass stops the bezel from not being flush.
So ideally, you shouldn't get dust problems once that glass is sealed.
Now I'm torn on the glass/non glass thing. Rage.
