- 22 Mar 2009
1 hour is not stable![]()
I only ran for a quick 1 hour, so I can do try a long prime test on the 4.6, 4.8, and 5.0 as I already done 1 hour on 4.2, 4.4 because my other old chip failed BSD in less than 30 mins on 4.2 and 4.4.
Running 4.5 GHz at 1.24v all looking good! My new batch number: L040B354
would aim for 50 runs to start with, then some general everyday use, then an overnight prime, then some general everyday use, then maybe a 10 run IBT, then some everyday use, then a longer say 24hour prime. if it manages all of that, then i would say then until it BSODs in everyday use you are as stable as you can be.
good point
but temps were ok, so i was happy
