I have that exact HU, dunno how you think it's garish (it has a dimmer to turn down the brightness)
Streaming from a W995 right over bluetooth, handfree is fine too.
It's got "for ipod" plastered all over the box too so i'm guessing the hardware is setup to stream over the cable.
Don't know if the iphone would run AD2P due to it's crippled bluetooth.
I'll give mine a try in a bit, need to put some music on it first though!
I have a Sony BT2900 and it performs this function just fine.
My only criticism is that it doesn't have a play button meaning that if I'm using Spotify I have to manually start a track when I first get in the car (not a problem with Samsung's Android music app though), although this might be an issue with all headunits, or even A2DP/AVRCP. I'd certainly have a play with some in Halfords - connect your phone up and disconnect/connect etc. and check which ones work in a way that suits you.
I know it's not much use right now but iOS5 will improve the A2DP support to send track names and allow control from the car.
If I didn't want Handsfree functionality, and if Spotify wasn't so damned handy I'd probably go for a dedicated iPod in the glovebox.
I don't want to take my phone out of my pocket, this is why I opted for a BT headunit in the first place![]()
