like i said, my G620 ran for 2 days with onboard gfx (think thats HD2000 though) never tried it with my 2500k, although i have plugged my hdmi cable into the onboard hdmi to see if it saved power whilst watching a film, and it successfully did that. but again im not 100% sure whether that still partially used the gfx cards as they were still fitted.
You need to try it with sandy bridge.
i did however get the BSOD with the gfx fitted running IBT on a 4.6GHz OC due to not enough voltage on ram. so are you 100% sure its a mobo fault?
its been running since about 12:30 (but thats been installing windows, drivers, updates.....so not perminantly) so will leave a video on loop (disconnected from net so no pesky windows updates can restart the pc) and if its still running in the morning i can assume it doesnt suffer the same problem as yours?
