How much would it cost to change ?
Thanks Murray <3
I am not building this myself..... I know a local shop and a friend
I've been asking a gaming forum if the machines you've been giving me would run GTA and stuff, and one of them pointed this out..
Just to tell you, haha, just because you have an intel processor, you don't have to buy nvidia aswell. Intel and AMD Graphics are perfeclty ompatible, same with AMD and nvidia. If I was you, I'd go with a hexacore, i.e. Intel i7 or AMD Phenom II X6 T1100, though.
JordanH
For a start you can tell them they are wrong, HEx cores (as in 6) are only utilized in encoding and stuff liek that, for gaming they are no better, in fact they are inferior to a top end phnom II X4 (4 cores) simply because there are not many games that utilize all 6 cores.
Trust me on this, im new to pc building too, i built my first one 2 weeks ago and it was a piece of pie
you will want to go intel, they have the best gaming CPU's on the market at the moment.
Intel i5 2500k is the best out so far, i7 260k is slightly worse in some aspects of gaming, see hex core argument above...
http://www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN&groupid=701&catid=6&subcat=1275
motherboard, you can spend as little as a £100 or go thee xtra £50 and get one with lots of features, but would you use them?
I suggest this:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-051-AK&groupid=701&catid=5&subcat=1990
or this:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-443-AS&groupid=701&catid=5&subcat=1906 is a little more, but for a lot more features i.e. bluetooth, usb 3.0 bracket more connectivity ect
as for graphics, i suggest a nvidia GTX 560Ti
http://www.overclockers.co.uk/showproduct.php?prodid=GX-247-AS&groupid=701&catid=1914&subcat=1341
It is true what they say that you dont have to have Nvidia with intel, or amd with ati, it makes no difference, it comes down to which games you play and what brand the developers prefer (i think?)
Case, in my opinnion? you should get the coolermaster storm enforcer
http://www.overclockers.co.uk/showproduct.php?prodid=CA-235-CM&groupid=701&catid=7&subcat=29
For £80 with front panel usb 3 wich connects internally, 7 + 1 expansion, 200mm fan, and another one in the roof, brilliant value for money, but i understand its not for everyone.
PSU is up to you, go for a branded one, modular if you can, that alows you to only use the cbles you need this saving space increasing airflow.
This is just me, i would pick:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-LA&groupid=701&catid=123&subcat=2057
Great vallue for what it is and has been accepted in various reviews
Windows 7 and 500gb hard drive bundle is fine, you might want to buy a SSD (solid state drive) for your os and most used programs or games, speeds it up like **** off a shovel!
http://www.overclockers.co.uk/showproduct.php?prodid=HD-011-IN&groupid=701&catid=14&subcat=910
8Gb of ram is fairly cheap nowadays so if you can you should, but 4gb is totally fine for gaming.
http://www.overclockers.co.uk/showproduct.php?prodid=MY-098-KS&groupid=701&catid=8&subcat=1516
Any optical drive will do providing it is SATA
GO for the thermalright silver arrow, best air cooler on the market! however failing that you can also go to this:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-072-AK&groupid=701&catid=57&subcat=1395
