Juddering while gaming
Just been looking at my power supply but probly not due to this but thought id mention we both have the xfx pro 550 w . mines ok . Her case around it is the wrong way round writing on the side is upside down and the power socket at the back and the badge are correct if you was to filp it over so you can read the writing on the side it wound make the back socket upside down and the badge . They messed up lol. fans right way round with it like it is . I thought there was something odd to mine when i put hers in . May be it would bother some one wanting it spot on but its ok with me
MOHAA is the best game ever. You're making me want to reinstall it now! :(
I spent many a teenage hour playing Multiplayer...
Omg, seeing those maps makes me want to reinstall. Damn I miss it.
Oh wait...
it also brings back fond memories for me, between mohaa, cods 1 and 2 and bf 1942, nam and bf2. damn....
lmao loads play our servers are full most of the time ..
our website is www.gkclan.co.uk you can see our server lists there also
Its still a really good game and some nice peeps play not like the kids in cod lol
Saying that we have Cod servers also ...
Any way back to the topic lol need to sort it b4 she beats me cos she says it was better before i messed with it
Did you use to have a NBKServer?
Might just be a different revision, or XFX used a different OEM in a later version of the PS.
No mate i didnt .
Its not the antivirus thats norton same as mine and ive looked but its not causing any problems .
The hard drive in hers gets quite hot so today im going to get her a new case and HD .
The HD at min is out of and old compaq im thinking its that as its getting hot and thats with the side of the case off all the time and with fans running
I will see what it does
Have you played it since cos you will be like wow its still dam good .
If not just try it theres still a lot of servers out there and players . You can always uninstall.
After playing like black ops and bfbc2 ive looked and thought for a really old game back then mohaa it still very good, And you can interact better one to one in with peeps and have a laff better than you can in the newer ones.
you forget just how good it is .
have you tried installing directx from windows website. has helped me in the past.
When you say you are using an old hard drive, you did format it properly before reinstalling windows and everything on it?
Before you do anything... I's suggest you run a simple benchmark to see what the computer is capable of. Follow the link, download it, install and click the only button available when it loads. You'll soon see if it's a slow hard drive using that.
Post the results back here as well.
https://novabench.com/download.php
EDIT: nevermind :D
