arrggghhhh i hate vimeo the videos load so slowly. do they load slowly for you guys?
Yeah that's what's happening and I figured it was bad!
Any suggestions on a good fork to go for? Based on GT avalanche 3 frame etc!
Fraid not. It's gonna be budget forks that I have no experience of. Perhaps a downgrade of rotor size would be a better bet? You don't need anything powerful in Norwich anyway.
Does anyone bother with fork lube? I seen some advertised in a magazine but never seen any of it around. Is it worth using it? Or is there something better to do/use?
I use Fork Juice too.
It's as essential as oiling your chain IMO. Some fork seals are poor, so keeping the uppers clean saves worn stanchions and keeps the forks running smooth. Alternatively you can use chain oil, but the silicon spray works better.
The first climb nearly destroyed me on my 2nd non-stop fast lap.two laps of cwmcarn yesterday - first climb was horrific, but the rest was awesome
You came to a computer dork forum, and the first post you ask about speccing you a bike?
How odd.
would you use the spray to do the rear air shock too like the fox rp2?
