Think the issue with this one was due to the BMW systems going nooooooooooooo can't do 170mph at the rear wheels whilst the fronts are stationary!
Damm nice car. The colour is a lot better in real life than the 'idea' of it is, if that makes sense. The only thing I've ever struggled about with Porkers is their interiors.
Love 911s, always have. Can't drive them for toffee. But then again I can't drive the current car either (without screaming and clenching), so hey ho.
Not sure who it was who came on a passenger ride after I did the 'road, but I loved the 'computer has gone crazy! Not sure if traction works!'... It didn't, and he looked at me like I knew what I was doing. Comedy.
Computer: STEERING LOCK IS ON! STEERING LOCK! NO TRACTION! YOU"RE GOING TO DIE!
I didn't. Although it was a bit squirmy. Got my chicken sandwich though.
Thats a nice result for Peerzy's Boxster S. Not loving MacRS4's result though
Who's was the Merc SL?
License plate details are in every print out. Considering you remove them from photos is this wise?
(I've always wondered why you bother to remove them anyway).
G18 WTF - quite like this.
I've never understood why people are so anal about having their reg on photos removed. OMG someone might steal it.. err they have to locate it first..
It's on display to EVERYONE that passes the thing in daily life anyway, if they wanted to clone it/steal it they'll do that anyway AND they know where it's parked.
I've gotta say though the stand out car for me was Gibbo's 911, I don't think I've ever been so impressed with a car as much as I was with his - got me looking on PH now and looking to sell a kidney for one!
They are apparently 290bhp standard, 295bhp when it got the facelift about 8 months after mine was built so I'm very happy with 298bhp. Makes me feel a little better about getting a newer 987 Boxster S and not going for a 996 911 as the 996 made 300bhp~ yesterday so nothing really in it.
So you can photoshop it up to 320hp?Also if possible could I get the pdf of the graph for my run sent to my trust email please.
Think that is partially down to the tip box not giving a completely accurate reading, If you look at our drag readings they are exactly the same, which we know would not be true between a manual and Auto, so I suspect the 996 actually has a bit more power than that recorded, but at the wheel power is nigh on the same, only problem is you got a poor mans Porsche
The computer went nuts after that run. Steering lock is on! Traction doesn't work! Wowa, no ABS!
Recovered after a bit.
If the coast down is conducted in neutral then surely the increased drivetrain resistances found under load when using a traditional torque converter automatic over a manual are not represented, and as such the calculated flywheel figure is too low?You know?
You do realise the coast down drag figure in done in Neutral for all cars don't you?
The toque converter is not engaged during the drag reading figure, hence I see no reason what so ever that the drag figures should be any different from the other porsches run that are of similar design
also...Audi and Maha said:Due to their higher load-dependent losses inside the drive train the
measurement values of vehicles with automatic transmission (incl. Multitronic)
have to be corrected as follows:
Tiptronic: + 3.5 %
Multitronic: + 4.5 %
Audi and Maha said:2.) Load-Dependent Losses inside Gear
The difference of losses between unloaded and loaded condition of standard singleaxle
drives is approx. 2 %. Systems which supply energy to the drive train during
drag power measurement (e. g. hydraulic pump drive for vehicles with automatic
transmission) have to be regarded separately.
Thank you for videoing my car Mr Kosta
Not one single photo of my car I see![]()
