100,000 mile club
[TW]Fox;19310942 said:
How could you possibly know that Rover was on its original turbo?
Everything from a wheel nut upwards was in the history, literally everything. And also, the turbine side was as rusty as ****, my 120,000 miler I used to have was far less corroded. Seemed the logical assumption. :)
What car is it?
VW Passat TDi 115
What mileage are you currently on?
230,000 ish
What major parts have you replaced?
Turbo, injectors, Clutch, Suspension
How long do you intend to keep the car for?
As long as it lasts
1998 Honda Civic 1.8 VTI
Mileage- 153,000
major parts: Suspension Dampners (not sure if thats really major part)
(original clutch ,gearbox etc - owned it since 72k miles)
What car is it?
BWM 318SEi 1995 model
Sold it on 200,001
Not much! Front lower wishbones, radiator and rear springs. Not bad for 8 years /75000 miles!
Reluctantly sold it 3 months ago, but it's still going strong!
What car is it? 1991 Mazda Eunos 1.6
What mileage are you currently on? 140,000
What major parts have you replaced? Only had it a month or so but replaced clutch and alternator
How long do you intend to keep the car for? Until it breaks, got a lot I want to do with it first however :D
Awesome!! Thanks for sharing that very special moment with all of us, and your membership to the 100k club is approved. :)
Cheers. :p
Youtube video of the rollover to 00000 would have been better though :p
It sat on my drive at 99999 & I had planned on taking another pick at 00000 but a mate came round & when we went out in it I forgot. :(
It currently sits at 00005 so it's Brand new again. :D
What car is it?
2006 Vectra C elite 1.9 cdti 150
170k
Inlet manifold, clutch and flywheel at 140k
6th March 2013 the day she hits 7 yrs old :)
Glasgow council have a policy of all PHC's being no older than 7 yrs so she'll be getting replaced with funnily enough another vectra (just need to find a tidy last of the line veccy now)
What car is it?
BMW 530d, November 2004
Just passed 130,000 last week.
Turbo, catalytic converter, exhaust, particulate filter, exhaust silencer, inlet manifold, exhaust manifold, another turbo (under warranty when I complained a year after replacing the first one that noise that had developed), 4 glow plugs. Front and rear discs. Changed body and wheels to sport kit, replaced springs and anti-roll bars to Eibach Pro-Kit. Various control arms and ball joints replaced recently. Gave me serious expense a couple of years back but has been pretty much faultless for the last 30,000 miles. Electronically it's been very well behaved, only needing a new wiring loom to the boot lid, and a slip ring which was causing airbag faults.
Not going to get rid of it, I've poured that much money into it over the last 4+ years that the only person going to get the value out of it is me, by not changing it. It goes well anyway and has a load of little extras above the standard spec that I do enjoy. And since I upgraded the appropriate bits to bring it to sport spec, it still looks very fresh, handles exceptionally and is still a joy to drive.
What car is it?
1997 Corsa 1.4 Vegas
100,004
Nothing
About another fortnight as I have a new car in the pipeline :)
Bought the Corsa 2 years ago for £50 with no MOT or tax. Put a battery and back box in it and it sailed through MOT. Done 4000 miles in it and replaced the back wheel bearings and one section of brake pipe in those two years :) Best 50 quid I ever spent !
It's the Garrett T25 isn't it? My Rover 620ti was on it's first at 196,000 miles too, tough old bird.
T28 ;)
I know that wasnt aimed at me but mine has complete full nissan service history since it was made, I have 1 folder and 2 plastic wallets full of paperwork :)
I joined the club on Saturday.
What car is it?
Saab 9-3 1.9 TiD (150) Saloon
100,100ish
Alternator - under warranty around 50k
Heated seat element (lovely in winter)
Water pump / cambelt - pump siezed at 64k (ish), which takes the cambelt with it. Thankfully no other damage and Saab paid 50% of the repair price (without me even asking) with the car only just being outside warranty
I purchased it with 2k miles on the clock as a dealer's demonstrator, so almost 100,000 miles in my ownership. I have a fixed price service plan in place for the next two services (108k and 126k IIRC), so plenty mores yet (fingers crossed!).
What car is it?
1995 Toyota Supra SZ
101,000
Just done a big service, plugs, all belts + tensioners, oil, oil filter, coolant, rear pads! Put new UK spec lights in aswell, wasn't essential but they look a lot better.
I think new disks & pads are in order with braided brake lines and a caliper refurb!
For aslong I keep enjoying it! Turbo-ing once I have the money.
What car is it?
2002 (52) BMW 330d
166,656
  • PAS pump/pipework
  • Turbo (and Intercooler/associated pipework)
  • Radiator
  • A/C compressor
  • Two brake calipers
Just been sold after 2 years (purchased on 135,000~)
What car is it?
Honda prelude 2.2vtec
149k+
Nothing (done 20k in it i think)
until the MOT expires :D
What car is it?
2004 330d Sport
165k
Full suspension ( for the lulz ), Gearbox, gearbox mounts, engine mounts, ballast, power steering pulley, pressure converters, egr solenoids, vacuum hoses, water pump, thermostat, egr thermostat, 1 hose and now going to be a rusty arches next most likely.
Probably another 2 - 3 years, probably try to get it to 300k.
What car is it? V-reg Vauxhall Zafira Di Elegance
What mileage are you currently on? 207,000
What major parts have you replaced? None!
How long do you intend to keep the car for? Until she changes her mind (couple of months at least!)
What car is it?
2002 (52) BMW 330d
166,656
  • PAS pump/pipework
  • Radiator
  • A/C compressor
Did it go to another ocuk member?
