I don't get it at all. They've just ruined Corki! Blind was what made you able to use your gattling effectively without getting owned. He wasn't exactly played a lot as it was either.
Am i missing something? I'm genuinely puzzled about this change.
corki was easily the best non-utility AD carry in the game. simply put, your ad carry options are: if you need CC you pick ashe, if you dont need CC you pick corki, and its as clear cut as that for competitive play.
i dont think corki's nerfs are too bad, damage wise it is really minor. i mean -10 off base values on Q, unnoticeable, 0.05 ratio on e and 0.1 ratio off every 4th missile... thats pretty minor. im not sold on the blind nerf like, i'm not sure thats justified but gatling gun will rape hard regardless.
