Do you think it would be better if they used cods system to find enemies. The if you fire you show up on the map a while. I think that it's a really good fair system.
Ok now battlelog wont let me run the game because aparantly theres a game running in the background, I have reset origin and reloaded battlelog and it has done nothing i have even checked my processes and theres nothing there.
What happened to the age old system of nothing but your brains and listening out? that not feasible anymore?
What happened to the age old system of using your brains and listening out?
Absolutely crazy. In the old days this kind of thing was a hack. Get rid.
As much as he keeps banging on about it to us, he isn't wrong about it. What you're looking at in that video is a guy sat well within a bush to the extent he can't actually see out of it, however with 3d spotting that doesn't matter he just aims for where the spots are. You surely can't be alright with that?
main problem for me is the motion blur.
this isn't me spinning the mouse wildly or spinning round this is just moving the aim one inch to the side at my normal aiming pace.
makes the game unplayable as you can't see anything
Is it just me that doesn't have it but whats is that red thing next to the map?
Or did tefal put it there to cover squad names.
