Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
yeah but i cant play with any lower well i can but it feels horrible.
What mouse you got? I have a G9 and run that on default and find it fine i understand its a personal thing, but 2.3 to do a 360, WOW, think i would be far to heavy handed for that.
Set to default for the mouse see if that sorts it, then move up till it happens, get the best you can before the blur takes over.
Maybe good to play a few games with peeps on here, maybe add a few if peeps are about on friday my ID is EL_JOCK
really? as if it does work and gets rid of MB that would be an epic advantage other others.
Again try it and see, get back to me if it doesn't work, don't like it then put your backed up config back in. I don't see it as an advantage, it's an uneeded performance hog, nobodies vision is like that in real life, I can't play with post processing on anyway, I hate it, absolutely hate it.
Plus it makes me physically nautious so there's no two ways about it ;)
It will no doubt be in the final build in an option, the point is that it is there.
Like many new games though, (Crysis 2) they left it out and people had to make 3rd party tools, lazy developing when they make a console game and leave the options out in the pc version.
logitech mx revolution
I move my mouse under my hand and not my hand (all mouse movement done with my thumb and my little finger other fingers just hover above the mouse and press buttons when needed)
my sense has slowly crept up over the years now i'm just so used to it i can really play well otherwise, and my play style definitely needs high speed twitch play (no scope sniper/rushing like a madman)
Uhhm I don't think it can ban for modifying the config relating to graphics quality, I've been using it like many others for ages. It would've banned me instantly for modified files otherwise.
Let me know how it goes. HBAO is a big performance hog too IIRC. and FxaaEnable if you don't want AA for a massivho boost.
I need these off for a lowly 4870x2.
:confused:
My 4870X2 has no issues with the alpha, or most games.
well the alpha is just impossible to play for me.
Not sure if it's because they have the setting far far too high or if it's because i play with a very high sensitivity but even moving the cross-hair 1 cm across the screen results in the motion blur wiping out absolutely everything.
getting into a gun fight is just pointless movign the mouse to aim = screen massively blurred have to stop to see where they are to see where i have to move the cross-hair too, get shot by them blur becomes even worse or even just missing it blurs too.
honestly cant see a damn thing 90% of the time.
Sounds nice, looks pretty but so blurry can't make out anything, and the flash off the sniper scopes is just silly.
Also there seems to be a bit of lag between the kill , the animation and the actual notification.
This.
Well, had a good blast on the Alpha tonight and I think it is frankly superb.
To be honest, I wouldn't have a problem with the spotting as it is. I'd play a mix of HC and normal mode and both would be enjoyable.
My main gripe at the moment is I don't know how to request more ammo!? I always run out of ammo before people to kill.. Is there no tac GUI any more?
That and what's with the minute wait at the end where I can't do anything!?
I dont think the Q key is fully working, however if your team is more than aware of life they should spot above your head the ammo icon, which also works in 3D, so they can see you at all times however they cannot just aim in that direction and fire some over to you.
Gord I believe you can request it by pressing q at a team mate that can give it out.
Systems broke.
Well that's no good.. none of my squad were ammo dispensers. I need to be able to call out for ammo! Cheers anyhoo, and you too Jock.
Yeah we need the commo-rose on PC, social key is inept.
Status
