Hey Guys
Here we have something very special for you today.
This is the Sport range of Crucial Ballistix which is aimed at providing users with an easy upgrade that involves minimal fuss!
These incredible value for money modules give the end user the potential to tweak settings if required or the option to install your modules and get back in the game.
To celebrate the triumphant return of Crucial Ballistix we are giving you some special deals that are going to be live for 24 hours.
These deals are a special introductory offer across the entire range until 6PM tomorrow evening.
Crucial Ballistix Sport 12GB (3x4GB) DDR3 PC3-12800C10 1600MHz Triple Channel Kit (BL3KIT51264BA160A) @ £59.99 inc VAT
Overclockers UK brings you one of the most notable names in system memory today.
These high performance modules are engineered to deliver the fastest, most reliable memory for gaming and performance enthusiasts. Upgrading has never been this easy!
If you‘re new to performance memory and like what Ballistix has to offer, the Crucial Ballistix Sport Series is a great place to start. This line was created for mainstream users and general enthusiasts. They feature heat spreaders for thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility.
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade for any X58 based system.
- PC3-12800 1600MHz CAS 10-10-10-28
- Designed for Entry-Level & Mainstream Users
- Integrated Heat Spreaders
- 1.5v VDIMM
- Triple Channel Memory Kit, Ideal for X58 Based Systems
- Limited Lifetime Warranty
Was [£77.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT51264BA160A) @ £39.98 inc VAT
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any Intel Sandybridge or AMD AM3 based system.
- 1.5v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel Sandybridge or AMD AM3 based system
Was [£59.99] Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT25664BA160A) @ £22.99 inc VAT
Overclockers UK you one of the most notable names in system memory today.
- 1.5v VDIMM
Was [29.99] Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (BL2KIT25664BA1339) @ £19.99 inc VAT
- PC3-10666 1333MHz CAS 9-9-9-27
- 1.5v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel or AMD Dual Channel based system
Was [£23.99] Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 4GB (2x2GB) DDR2 PC2-6400C5 800MHz Dual Channel Kit (BL2KIT25664AA80E) @ £47.99 inc VAT
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any Intel or AMD Dual Channel based DDR2 system.
- PC2-6400 800MHz CAS 5-5-5-15
- 1.8v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel or AMD Dual Channel based DDR2 system
Was [59.99] Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
- 1.5v VDIMM
ORDER NOW
- 1.5v VDIMM
ORDER NOW
- 1.5v VDIMM
ORDER NOW
- 1.5v VDIMM
ORDER NOW
- 1.8v VDIMM
ORDER NOW
