I have to say though I used to not miss the heat a CRT generated in the room when on for several hours but my 24" Hazro is all aluminium so as you can imagine heat is exhausted in 360 degrees instead of just through the vents so you can warm your torso with it
The price you pay for quality materials eh!
It's extremely obviously those who are claiming CRTs are always better than LCDs, and how LCDs can't product a proper black, have only experienced a really crap low end LCD.
The black theme background for these forums is just as black my black keyboard is, colours are great and vastly superior to the CRTs of old that most people would have used.
I don't miss CRTs at all, I always hated them with the horrible headaches they used to give me (at any refresh rate).
There maybe something wrong with yours, do they ever get turned off?
The ventilation slots of the monitor are mainly located on the upper side of the curve on the back. In addition, two further ventilation openings are located on the sides. The ventilation slots are rather large in order to disperse the heat. Unfortunately, part of the backlight shines through in places, which might cause insects to make their way inside.
the new oled lcd's look sexy for blacks as they have no back light there.
hopefully we'll all be on120hz OLED screens soon![]()
CRT have better viewing angles also, I guess it;s a case of 2 steps forward, 1 step back...I still think LCD panels lack a lot of the image quality that CRT have. I'm not an expert, but the colour reproduction seems more faithful and the image is a lot more fluid. Plus, every resolution looks good and nice high refresh rates.
I have only experienced the good LCDs & they don't do better blacks than CRT.
My NEC 30" 2560x1600 £1800 my 2x NEC 20" 1600x1200 £500 each.
My Samung 30" 2560x1600 £1200 had the best blacks & it still could not match the CRT.
My £2500 "50 Pioneer Kuro Plasma has better blacks than all the LCDs.
The thing is over time you just get accustom to the blacks of the LCD.
