- 16 Jan 2003
- Nottingham
If you're only going to be running 2 sticks of RAM then the cooler doesn't matter at all.
I was told by a member on here the previous cooler I picked would have cause problems with the ram, thats why I decided to ask someone to choose me one from scratch on here.
It would only cause potential problems if you wanted to fill all 4 slots since the slots closest to the cooler might be blocked, you can use the further away slots and use any cooler you want.
Thanks a lot for your help so im basically there with my build would this be ok then http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-CS.
I will probably order all of this tonight![]()
Looks good, but I would change the monitor to a Samsung 3D one as they are supposed to be just as good colour wise and obviously it does 3D aswell
