Will a Corsair H60 fit sideways?
18 Jul 2011
So I don't have enough space for it to fit like this, with the radiator at vertical:
I was wondering if it was possible to turn the radiator 90 degrees to have it facing horizontally?:confused:
Thanks in advance,
Billy
If you mount it the other way, it's probably going to clash with your case.
The 12CM fan should make is so that the RAD isn't blocked, I'd have assumed.
