Problems setting up a static IP
8 Nov 2006
Ireland/Northern Ireland Border
I have just been trying to setup a static IP for port forwarding on my PC. I have been getting the error above. (Not my screenshot by the way)
I have managed to narrow this down to a local issue as the same settings work fine on another PC on my network. None of the setting I am using are incorrect so I am puzzled.
There's probably another network card with a gateway set up - Just press yes, and it should be fine!
This. You probably have the wired NIC setup with a default gateway too.
If it's the same default gateway on both NICs then ignore the warning. If its a different gateway you could get some issues.
I have two NICs on the mobo.
I tried ignoring the message and it just kills my net connection stone dead. I have also tried disabling the second NIC without any luck.
Just noticed the screenshot is from a wireless connection. This is a wired connection on my PC.
"Internet connection goes stone dead", can you still ping the gateway and internal devices?
What connection details are you getting from DHCP?
You can run multiple gateways if you wish but running multiple network connections on the different subnets with different gateways is going to get messy. You will need to play around with the metric weightings etc to get it to work how you want to.
I don't want to run multiple gateways. I just want to setup a static IP.
I can ping the gateway. It seems to be DNS that goes down.
When I switch to the 2nd NIC I can setup a static IP. Portforwarding in uTorrent still isn't working though.
OK - I am using the NIC that is working with a static IP and here is the ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : DeepThought
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller #2
Physical Address. . . . . . . . . : 00-24-1D-74-BF-53
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Physical Address. . . . . . . . . : 00-24-1D-74-B4-E2
Link-local IPv6 Address . . . . . : fe80::b4c3:7238:d0d2:ce4f%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.76(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 234890269
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-4B-40-8D-00-24-1D-74-B4-E2
DNS Servers . . . . . . . . . . . : 208.67.222.222
208.67.220.220
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:2c46:2fd8:a83d:5d72(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::2c46:2fd8:a83d:5d72%16(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{8EEFDC73-CF1E-439D-AF05-0950861785AC}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter isatap.{7AE0EA32-42B0-4C6B-A80F-600A3AEDE53A}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
Interface List
12...00 24 1d 74 bf 53 ......Realtek PCIe GBE Family Controller #2
10...00 24 1d 74 b4 e2 ......Realtek PCIe GBE Family Controller
1...........................Software Loopback Interface 1
16...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
18...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #3
19...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #5
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.1.254 192.168.1.76 276
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.1.0 255.255.255.0 On-link 192.168.1.76 276
192.168.1.76 255.255.255.255 On-link 192.168.1.76 276
192.168.1.255 255.255.255.255 On-link 192.168.1.76 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.1.76 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.1.76 276
Persistent Routes:
Network Address Netmask Gateway Address Metric
0.0.0.0 0.0.0.0 192.168.1.254 Default
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
16 58 ::/0 On-link
1 306 ::1/128 On-link
16 58 2001::/32 On-link
16 306 2001:0:5ef5:79fd:2c46:2fd8:a83d:5d72/128
On-link
10 276 fe80::/64 On-link
16 306 fe80::/64 On-link
16 306 fe80::2c46:2fd8:a83d:5d72/128
On-link
10 276 fe80::b4c3:7238:d0d2:ce4f/128
On-link
1 306 ff00::/8 On-link
16 306 ff00::/8 On-link
10 276 ff00::/8 On-link
Persistent Routes:
None
