Not sure i like a CPU with GPU built in either
? serious?
The Athlon Quad runs cooler than the Phenom
Sure about that? some Phenoms use 95W too.
Half the time I can't tell if you're trolling...
Is it an official statement or a "leak" - just like all the other "leaks" with other CPUs and GPUS??
Funnily enough the slides don't mention the H67,P67 or Z68.The slides mention that the Q65,Q67 and B65 chipset will not work with Ivy Bridge but the only noise has been about the Z68 being compatible.
At the bottom of each slide:
"All dates and plans are subject to change without notice"
This slide makes no mention of 6 series chipsets and is newer:
http://semiaccurate.com/2011/03/28/latest-intel-roadmap-confirms-pci-express-3-0-for-ivy-bridge/
Where is the official Intel statement especially concerning the compatibility for all the six series chipsets?? Until that is released in a statement it is all fud. Both Intel and AMD are guilty of this. Again lets go back to socket 775 and socket AM3.
a big LOL at you.the i3 2100 beats the phenom 2 x6 black edition on most benches, and even in gaming.
obviously it falls behind a little in multi threaded applications, but y'know. just sayin![]()
Much rather have an OCed Phenom II X4 than the i3-2100.
You've obviously never played Bad Company 2 on a dual core and then a quad core, stop giving bad advice man. Dude just get the quad core, don't listen to wannabedamned.Just so I get this right...
You guys recommend a quad core over a dual core, regardless of performance? Just because it has 4 cores? 4 cores that perform marginally better than the 2 core competitor(Some of the time) and lose out with regards to per core performance by quite a bit?
Gaming benchmarks show the i3 well ahead!!!!
I just find it confusing...I need it explaining!?
Surely its better to buy the overall better performer!?
I wouldnt,
http://www.anandtech.com/bench/Product/289?vs=88
Less power used too, and Ivy bridge support on all chipsets![]()
http://techreport.com/articles.x/20873/2That benchmark doesn't show BC2 which makes use of 4 cores.
I wouldnt,
