Hi Guys
Just got a ASUS P5QLD Pro motherboard in a Antec case. There are two 80mm case fans plugged into the 3-pin connectore for Chassis and Power fans.
Both are running flat out at just under 5000 RPM and are very noisy.
If I use the ASUS software it changes the CPU fan and it becomes slower and quieter but nothing I can adjust in the ASUS software or even Speedfan seems to make any difference to the other 2 case fans
Can anyone help as its just so noisy?
