What I can deduct from this is that while most people try to get a correct exposure from the get go, Ejizz purposely under exposes all his shots.
That fact just don't sit well with me, the fact that he purposely exposes his shots from in the first place so he can fix it later.
Better to be
able to fix it later than not at all, so ETTL is better in areas of high contrast.
Also confirmed by the below review I posted earlier comparing exposures with the Sony sensor.
http://www.pentaxforums.com/reviews/canon-7d-vs-pentax-k-5-review/comparison.html#drtest
The guy with the silver hair you can argue with but if he had brown hair you would still done the same anyway so I don't find your argument there to be valid.
His hair is the worst part, but it's not as if the side of his face isn't nuked either, besides the same would happen with blond hair, and even dark hair would still look over exposed as it's reflective...
P.s. Who cares about blown highlights lol I don't know why people are scared of that. Really don't.
Maybe it's because I started out in photography mainly using artificial lighting and learning to expose correctly and I considered ANY blown highlights to be a major fail on my part, as in a studio or controlled environment it basically looks cheap and tacky, and like you don't know what your doing with either your lighting or camera settings.
I basically hold the same view for stuff in natural light, I like even exposure with out clipping either highlight or shadow detail, unless your going for a deliberate specific look like a silhouette for example.
Ultimately I care MAINLY about the final image rather than how I captured it, ETTL is just a tool to allow me to even out exposure in post by simply moving a slider (which you would have to do anyway as the camera never exposes exactly as you want it), it also allows me more flexibility in post ( a decent retoucher will advise you to leave at least 0.3 stops of room in the highlights ) as often if I expose an image with zero bias, I then actually have to 'fix' the image by reducing the exposure slider if I want to boost contrast or if I run a few of my actions etc. etc.
So as I said this is just a tool for me, and like most new tools, some folks will always be try to reject them at first, like they did with things like autofocus, I guess it's just how it is sometimes.
http://dmongan.tumblr.com/post/7891241232/resisting-change
I personally prefer to capitalise on technology as it evolves, and use everything in my arsenal to achieve what I set out to.
