May have to change source on your monitor if you changing the input. What monitor do you have?
Works with the VGA output on the motherboard when the graphics card was removed. Can't get the HDMI to work.
Only worked with one of the DVI ports when the graphics card was installed but with graphical errors on the screen (white lines).
Power connectoes?... It was already pre-installed. I've since remove the graphics card. It was pushed into the motherboard tightly and had two connectors on the right hand side of the card. Does that sound correct?
Tried the source button. It cycles through 'Digital', 'Analogue' and HDMI but only seems to work with the VGA output.
