AMD Phenom II X4 vs Intel Core-i5 2500K?
30 Jul 2011
Discuss!! :D
*Im not looking to buy!*
I just want to see peoples opinions, As all I ever see is people screaming about Intels sandy bridge's, but Ive never heard AMD fanboys view.
HA! I like it when people say this it makes me want it so bad, BUT.. Is there a notable difference when using it, or are you basing the 2500k destroying it based on benchmarks?
Depends what your doing. Word processing? Probably not. Encoding? Hell yeah!
AMD Athlon II X3 425 @ 2.7 XD
You already started a thread on this before:
http://forums.overclockers.co.uk/showthread.php?t=18305635
Video encoding and gaming.
The CPU is for a friend(look at the link) and he has a £200 budget.
I already shown him benchmarks from a Phenom II X6 which will be a drop in upgrade for his MSI motherboard.
The PSU also needs an upgrade as it is a 450W Sumvision one.
Noo this one I just want to see peoples opinions on each processor and such. Like is the i5 worth the price difference. I already know what Im going to buy.
It depends on how much money you have and what you are using the PC for!!
If you have the money the Core i5 2500K is a very good processor.
Most setups with a core-i5 2500k I see are: Asus P8P67, The processor, Thermaltake Frio / BeQuiet! Dark Rock Pro and a corsair psu.
Coming in at ruffly £380
Probably been mentioned in the other thread - but in like-for-like tests against a Phenom II X4 965BE (£96) the i5 2500K (£170) is quite a bit faster.
However, the phenom II is quite a bit cheaper and if its performance is good enough for what you are doing then it is a good CPU to go for and saves you money.
If you do want the extra speed and will make good use of it then the 2500K is a great option - especially when considering that it overclocks from 3.3GHz to 4.4GHz without much trouble (so long as you have a P67 or Z68 board).
TBH i had a i5 750 @ 4.4ghz watercooled and sold it
now have a phenom 555 x2 @ 4.2ghz and i dont notice any difference
even when gaming the FPS just seem the same.
Thanks for the in depth answer! :)
