- 4 Jan 2004
- ¯\_(ツ)_/¯
mine buzzes for a while done it since release day. a lot of the 2405fpws had the issues, there afew diff fixes for em the most simplest of which was stick blutack in varios places. i was very tempted to try but never had the guts to ripp open the monitor at the time.
still happy with mine after all these years possibly the one pc related purchased ive used a lot every day. will prolly still put it to use once i upgrade to 30" screen later this year tho
Blu-tack is a good shout. Non permanent, and non conductive, so I may try experimenting with that.
What do the other less simple fixes involve? I know hot glue is also pretty good at stopping buzzing as long as you know which parts to glue...
Also these fixes may prolong the life of your inverter...The buzz is pretty annoying, especially after going to so much effort in order to build a quiet PC, now all I hear is the buzzing from this screen on lower brightness settings... which is a bit of a shame as apart from the buzzing issue these screens seem to give a very nice picture.
