Remain seated or stand to wipe?
Status
Not open for further replies.
Caporegime
29 Aug 2007
Auckland
You've just had a poo and are ready to start the wiping process. Do you remain seated and do the tried and tested reach behind whilst remaining seated move or do you go for the more adventurous semi-upright cleaning position, e.g. squatting, hovering or fully standing?
I ask this for reasons of science (also, I read it on another forum and I want to believe that no one really stands up to do this and it was a huge misunderstanding).
I think a better question would be do I remain seated or stand up when closing threads.
I'll give it some thought.
you cant stand up and whipe? over weight? bad diet?
Where the hell did that come from? :confused:
i tend to stand up because 90% of the time when i whipe there is nothing on the wet whipe.
How is that a reason for standing? Why would you stand up? Your arse cheeks will squeeze together then.
Stand up.
Wasn't aware there was another way.
And this is what I found amazing. There quickly appeared two camps of people who couldn't believe that there was another way to wipe. It was hilarious (it wasn't, it was terrifying).
I'm firmly in the stay seated category, you hovering psychos :mad:
well i dont have a massive fat ass so the cheeks dont crush together and if there is a clanger i can feel it before i stand up :S
its obvious when you have a bad poo and u must try to whipe before standing up.
How can you possibly wipe your arse properly while standing up :confused:
you have ever tried it? unless your over weight its easy crouch down then stand up sraight, see if you notice the gap between your cheeks spreading/contracting? mine doesnt maybe i dont have a fat ass so the gap stays relatively stable? making it just as easy if not easier to whipe standing up because then i dont risk wee dripping on my hand
If you stand up there is a chance I fear that the poo will stick to the insides off your cheeks and be harder to wipe off.
I therefore like to remain seated and leave it wide open for easy access and less likelihood off stickage
Maybe you just have really undeveloped glutes or something.
Why bother even sitting down at all if you can wipe while standing?
How to wipe your butt
It's crucial to remain seated!!
Are you saying that your anus is on display 24/7? Surely everyones cheeks close when you stand up hence why it's called your arse crack and not an arse canyon :confused:
It sounds to me like you have no need to sit while having a poo, the whole point of sitting is to spread your cheeks so you don't get poo on them.
Status
