- 23 Apr 2009
- Cheshire
Out of interest, how is it better when connected to an Intel PCH controller SATA II rather than to a dedicated eSata port controlled by an add-on-chip?
The motherboard only has six native SATA ports - these are controlled by the intel platform controller hub (PCH) which is very quick and has a close connection to the CPU. Therefore, use these ports before anything else.
In contrast, the eSATA port is controlled by a separate controller chip (which doesn't perform nearly as well as the PCH) and is hooked onto the PCIE bus.
In conclusion, if you use that adapter then you will certainly make full use of the drive you hook up to it.
2. How safe is the "OC Genie 2" on the MSI mobo, will it OC your CPU to a safe & stable level or is there still a chance with this feature that the CPU could become damaged?
It’s really very safe – the feature doesn’t push the CPU to the limit (you would need to do manual overclocking for that) but it does give you a respectable overclock – 4.2GHz I believe in the case of a i7 2600K. All you need to do after it has set you up the overclock is check the temperatures are safe under load (using coretemp) and enjoy the extra speed.
As for damaging the CPU, don’t worry about that – the feature is made to be conservative by default and if anything funny goes on the system automatically turns off before damage is done.
3. You have said that the BLCK (FSB) is not changed by the OC Genie, but what part of the CPU is changed along with the memory (sorry for newby questions!)?
When overclocking a s1155 CPU the main settings changed are the CPU multiplier (which is unlocked on the i7 2600K) and the CPU core voltage.
1. Does the Asus P8Z68-V mobo have an auto-overclocking feature?
Yes, the ASUS boards have “Auto Tuning” which is a similar feature. But I understand that the MSI implementation is considered to be the best.
2. Does the Asus mobo have high quality components?
It doesn't have bad quality components, but the MSI boards are specifically made with components that last a long time and don't require as much cooling (since they can safely run hotter).
Also, S1155 boards have had reliability issues in the past (for the P67 series at least) and the Z68 series has only recently been released. I hope they got it sorted out, but I know that MSIs P67 boards were solid.
1. Can you explain why video editing software needs GPU acceleration nowadays please? (i know nothing about GPU's). Just want to understand why I need a GPU for video editing? I should mention that the video editing I will be doing is nothing professional. only hobby. I don't know which video/photo editing software I will use yet, will need to shop around. As for digital audio editing & recording software, I will be using the new "Sonar X1 Producer".
It doesn’t “need” GPU acceleration per-se as you can still use the software perfectly well with the CPU running everything. However, software developers have come to realise that in terms of raw computing power, the graphics cards in modern computers are often many times more powerful than even high-end CPUs –so long as they are used in the correct way. Hence, software has been introduced to tap into this extra computing power – that is why you see “GPU accelerated” on many applications these days, including video players, web browsers and Video editors.
You may not want to invest in a discrete graphic card right now – but if you think you might in the future then I would certainly go for a Z68 board now – so you don’t lose Quick sync if you do move to a discrete graphics card (as H67 boards disable the onboard graphics (which powers Quick Sync) if you install a graphics card).
1. It may take some time before I will run in RAID so am I best to just have 2 x internal HDD's (both same models & GB for when I run in RAID) & 1 x external HDD for now as a back up. If so, would you suggest that i only use one of the internal HDD's just for the OS & program files & the other internal HDD for storing all of my audio & video files? Is this the best way? Maybe later down the line I will invest in an SSD.
So long as you backup regularly then that storage arrangement would be fine.
