*** Official OcUK Minecraft Server - Discussion and Rules ***
Looks good but also looks very abusable.
Like being able to put redstone on glass?
torches can be put on anything again.
I like the idea of being able to make proper furniture but
this mod looks like it will allow many other things that should not be allowed.
Is it bad to be able to put redstone on glass and/or torches on anything?
Genuine question as I've not played much for a while.
well it is not an intend use of redstone
and torches where removed from being able to be put on glass and leaf blocks and it was deemed a bug.
I only used them for examples as i am unsure what else might be "NOT" intended for each item. I was just pointing out that this mod would allow for this sort of thing and i dont know if this will then allow for other abusable bugs
it would need to be tested ofc. I am not agents the mod as long as it does not take from the game and how it is intended to be used. :D
just to add as i just thought of it now.
Will everything that is done on the server get undone like it did with the piston mod when the srever restarts
or will the items dupe again like with the piston mod.
I've stuck it on the test server that I've brought back up. I've had to delete permissions on it so it's likely that people won't have the proper abilities to do normal stuff though.
I'll post something here when I get a chance to make it more usable - will possibly be tomorrow now though.
if you want someone to help test :D that is iff you dont have your testers already.
People are welcome to jump on, though for now I won't be handing out OP to anyone (need to sort permissions first).
linktart.co.uk:45565
Cheers for the feedback guys.
Has anyone attempted the Mob Arena much? I'm just wondering if the rewards for surviving (10 waves and higher) are too much...
I haven't tried it since the last test server. I don't even recall what the rewards were, but I would hate to see it used to farm items continuously and make that particular item then lose it's value in the server.
i.e. like logs were with autofarming, sand by zumiis worldedit etc
The way I've tried to balance it is that you'd have to spend a similar amount of time working at the arena as to how much time you'd spend looking for ore. For example, completing wave 30 gives you a single diamond ingot atm, wave 10 or 15 or something a gold one. I've no idea how well a properly organised group could survive - I'm hoping that most wouldn't make it to 30 but some dedicated/experienced players would be able to with a bit of work, getting them rewards on a similar level to those they would receive if they spent all that time mining.
To be honest, I imagine the way that I've balanced it most players would be better off mining but the arena could be a fun distraction and still net a useful reward.
