Do you need a car though?
If you don't need it, may I suggest saving the money, get a taxi when you need to and get it when you need it. The older you are, especially over 25, the cheaper it will be. It really is no point getting a car if you are sacrificing too much of your other part of your life for something that sits on the drive a lot.
also you could keep the car in a better postcode area, any family in the country?Just passed my test! What next?
best option on this is buy and insure the chassis of a moped or a 2cv and start racking up NCB cant really crash a car that doesnt movealso you could keep the car in a better postcode area, any family in the country?
I recently got my first car and it was a choice between basically a Fiesta 1.25 and a Focus 1.6 - in the end I ended up with a Fiesta 1.25 and I love it![]()
I can't wait, just for that extra freedom it makes it worth it in my opinion, at least in my current situation.
It's truly awesome and worth every penny. So much better than crappy public transport! Wish I did it years ago.![]()
Well I'm going to save up for a couple more paydays and see where that gets me, should have best part of 2k in about 6/7 weeks time.
edit: good shout on the yaris, I can get one insured for about £2200 so that's a bit of a saving.
That is still pretty insane. I would have thought you can get it lower than that. Try ringing the companies directly and see what they can do.
Same age as you as well. **** living in Hackney
especially when the same comparison site quoting you £1000
