- 12 Jan 2009
Lol and when the 6 series comes out from Nvidia its gonna be more powerful than that card and less than half the price so good luck with that!
What is microstutter ?![]()
It was the ATI hd4xxx series in that video above.
GPUs have come a long way since then.
It's called a different opinion, which is absolutely fine. I'm a pretty anal person in general. I still think that the fact that microstuttering still exists is nothing short of ridiculous and will always put me off crossfire, which is a shame. I am very sensitive to that sort of lag, though.
This video demonstrates what microstuttering is.
Basically, the gaps between rendered frames are uneven. For example, if the frames were locked at 30 per second, each frame should be output ~33ms apart (and 60fps would be ~16.5ms apart.) With multi-GPU setups though, they just aren't. This causes the video to be more juddery than it should be with the same amount of evenly-distributed frames. From what I have read, the reason is unknown why this happens (otherwise it would have been resolved?)
the buyers of 650 quid GPUs to me are mad, but there is a market for these, and so whats the problem?
Some people are more sensitive to small lag spikes than others. I'm guessing I am sensitive to them as I make sure I play games at a solid 60fps and never any lower (by lowering settings, if necessary), so my eyes are used to smooth-as-butter video.
This is just what I've made out of the whole microstuttering malarkey. Don't expect what I have said to be completely factual. Hopefully it is all correct, of course.
I understand this isn't the best of threads to post this in but it was an asked question and I didn't mind answering it. No point in a new thread.
The problem is that 3x GTX 580s are faster and cheaper than this.
WHAT COST £999 +VAT? ASUS MARS 580 X2!! **
Correction £1,199.99 inc VAT.
How many members here don't pay VAT?
If you had equivalent frames then it would be an issue but the whole point of SLI/Crossfire is that you get way more frames.
