Edge - 9/10
I think you need to change your download location also![]()
Still says the 26th.
What VPN you using?
Sadly, I don't have money to pay for my usual VPN currently, so can't check it sadly![]()
I'm using a free one called hotspot shield.
Yeah, I don't think it works properly then.
I had a free dial up American VPN that worked when I did F1 2010, before I had access to a proper VPN. Sadly, I've lost the dialer program
Also, I think Hotspot Shield only deals with your browser, not applications that use the internet. Normally this wouldn't be an issue for me![]()
Ah ok, well iv'e managed to sort it now but thankyou anyway.![]()
DXHR is available on all three major platforms, and through the course of the previews and reviews, I’ve had the opportunity to play on all of them. I can say pretty definitively that the PC version is the strongest. In addition to the amped up performance and the added features like the game’s AMD Eyefinity support, it just handles better. For example, the hacking minigame on an Xbox 360 controller is a bit of a pain, requiring manipulation of the analog stick that sometimes doesn’t result in your commands going through. In hacking, every tenth of a second is important, so having commands fail and having to track around the game space with an analog stick is painfully wasteful. Hacking with a mouse, on the other hand, is a breeze and much more effective. It’s little touches in the interface like this that make the PC version superior to the console experience — it just works much better in lots of tiny ways that add up quickly.
