- 16 Jan 2003
- Nottingham
that may be true but i went from a Q6600 @ 3.4ghz to a I3 2100(will be getting i5 this month but was to get system on buget at time) and i have seen a huge improvement in bc2 but my 5830 is poo going with 6850's in xfire so it can chew thru bf3 XD
so why not just get another 5830
your swopping a 6850 x 2 which are same as a 5830 . pick second hand 5830 and away you got and a decent wedge saved.
low quality setting @ 640x480 ? Who plays at that res and setting? They are straining the cpu and not really showing a real world example like 1920x 1200, 1920 x 1080 etc what most of us are using now. Is there a different res test of that and some real settings, so that way the graphics card is put to work not just the cpu fighting to hit frame rates not needed? Linky pls
NVM found the site with other tests they did.
http://translate.google.com/transla.../-FPS-/-TPS/Battlefield-3-Alpha-test-GPU.html
While your right about the 640x480, ruining at 1920x 1200, 1920 x 1080 etc will not bring the fps down enough to make the dual cores look any better in that test.
Come to think about is, if my pc will only achieve 25fps in low detal at 640x480, the game is very poorly optimised and I can see there will be a few moaning ppl.
I think Ill be upgading before it comes out, prob to a i5 or bulldozer depending whats the fastest at the time of upgrade.
But I'll be quite gutted to get rid of current system, as its lasted me far longer then any of my previous builds, I build it 3yrs in march and its been a excellent system.
Hmm... slightly worried how my opty 1354 @ 2.2 is going to handle it. As I'm gaming on an ML115 I can't upgrade the CPU...
It's a CPU test, find me a site that does a CPU test at a high res with max details, you won't, that's how they are done, they take all the strain off the GPU so they can test how the CPU's actually compare, so less of the rolleyes.
