Can't install MSN
1 Jul 2011
Hi there,
I've been trying to install MSN and I can't as I'm keep getting the error shown in the image below.
How do I fix this /:
Thanks
Open REGEDIT as an adminstrator, then browse to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\DA42BC89BF25F5BD0AF18C3B9B1A1EE8\108B43C0CEA676640B35306AE7D24051 and check that sufficient permissions are granted.
That ain't in there /:
Anything like Kaspersky running that may be stopping this from being installed?
Tried running the install file as admin?
Failing that I have no idea I don't use msn.
No, they is nothing like that running.
Well I'm already the admin, or do you mean right clicking on the installer and running as admin?
What did "Get more help with this error" give?
Why cant you use Pidgin? or eBuddy? or dont use any IM. Use Facebook or Twitter or something?
What are you trying to do?
Try right click and run as administrator....have you also tried re downloading the installer?
I've jut run it as administrator and till the same.
The "Get more help with this error" just take me too the hotmail login page. I log in and jut take me to home screen.
:o
In that list, nothing at all should be stopping it I would say it was more of some corrupt file structure or registry somewhere.
Thanks,
When I ran Ccleaner and ran the registry thing it came up with something like 500+ problems.
Missing Shared DLL C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Warranty\CASLExec.exe.hpsign HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\SetupA2.exe HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\SetupAC.exe HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\103C_53307F\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\103C_53316J\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\103C_53335X\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\103C_5335KV\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\103c_5336an\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\guid\guid.zip HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\guidcpc\guid.zip HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\HP-MultiPlatform\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\MultiVendor\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\Projects\103C_53307F\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\Projects\103C_53316J\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\Projects\103C_53335X\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\Projects\103C_5335KV\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\Projects\103c_5336an\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\Projects\product_line\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\Projects\SDMS\Dashboard\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\Projects\vista\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\Projects\vista2\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\ACO\Vulnerabilities\Adddata.cab HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Users\ADMINI~1\AppData\Local\Temp\Ceement\src\setup.exe HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Missing Shared DLL C:\Windows\Help\oem\scripts\WW\launchAP.exe HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDlls
Unused File Extension .iso - isofile HKCR\.iso
Invalid or empty file class .cab\OpenWithProgids\WinRAR HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.cab\OpenWithProgids
Invalid or empty file class .WLMP\OpenWithProgids\WindowsLive.MovieMaker.WLMP HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.WLMP\OpenWithProgids
Open with Application Issue "C:\Program Files (x86)\CyberLink\Power2Go\Power2Go.exe" "%L" HKCR\BlankCD\shell\OpenWithPower2Go
Open with Application Issue "C:\Program Files (x86)\CyberLink\Power2Go\Power2Go.exe" "%L" HKCR\BlankDVD\shell\OpenWithPower2Go
Invalid or empty file class Picture HKCR\Picture
Invalid or empty file class VideoFiles HKCR\VideoFiles
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{01F4883E-DB31-4ECB-A196-9B58867CC8D4}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorHMT.dll HKCR\CLSID\{0262E712-0CA7-41F5-93A1-B8706944EED9}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVidEnc.ax HKCR\CLSID\{09C8D515-5C6A-434D-AD92-FEF7EB153310}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{09F08EC6-8AF2-4749-8DF4-5FF18354DD00}
ActiveX/COM Issue InProcServer32\C:\Users\Spotty SJ Rope\AppData\Local\Google\Update\1.3.21.57\psuser.dll HKCR\CLSID\{0E55CBE1-B06A-49B6-AD8D-9EFAA0160C6F}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GRGL.ax HKCR\CLSID\{0FC30BF9-02EA-4952-B77C-3FEB93358F99}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GMP3Wrap.ax HKCR\CLSID\{11A947C3-BABC-466E-A678-1FFEC95EB2F8}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAudioCD.ax HKCR\CLSID\{15C2BA5D-111A-4139-82A4-21A36546C8B4}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\TemplateMgr3.dll HKCR\CLSID\{1ED134BD-1AD7-4158-BF79-ADC83DC034DC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GEdtKrn.dll HKCR\CLSID\{1FFBD0F1-80CD-4452-8AC4-8FBEED892AFD}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GBufferMgr.dll HKCR\CLSID\{24245687-122E-4E57-AD9A-B433C0321357}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GResample.ax HKCR\CLSID\{25B715B0-955F-4B5C-A70C-CB4335669CC0}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorHMT.dll HKCR\CLSID\{2908C177-05B9-491D-89AC-059611E1B140}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{292E914E-FE23-44E9-8193-FCA9F5FD444E}
ActiveX/COM Issue InProcServer32\C:\Users\Spotty SJ Rope\AppData\Local\Google\Update\1.2.183.39\goopdate.dll HKCR\CLSID\{29A96789-9595-4947-BEDB-0FCC776F7DB8}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorHMT.dll HKCR\CLSID\{2A4520C8-B244-4DF1-BE76-7E32E2D739D5}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVideoStabilizer.ax HKCR\CLSID\{2BF98AC9-2B5B-4696-9D21-FDBDC18BD765}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Pando Networks\Media Booster\npPandoWebPlugin.dll HKCR\CLSID\{31261F21-2B16-45EE-BEAB-07C4CFA18B65}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\CyberLink\MediaShow\subsys\UACAgent\UACObjectPS.dll HKCR\CLSID\{31DAFDD5-C9C6-46E8-BB6F-7434DFCBBDA6}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GResample.ax HKCR\CLSID\{3287631F-CFCE-41E4-BEF8-DF0F2ECA2F4F}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\MediaCache.dll HKCR\CLSID\{328B66FF-A9FD-4823-9F1C-92FAFFCC4F2E}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVSD.ax HKCR\CLSID\{3484F78F-F8CE-4CF3-914F-10F1A76BF0D5}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAuNRWrapper.ax HKCR\CLSID\{376D7F36-1C75-438A-BC0F-DD4D6348580D}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{3B755515-A4DB-40DA-84A0-49F62B1F9814}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{3C26CD87-4D0B-483E-8174-61F35C9A239C}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{3CC2B229-4B05-479D-8A09-9B24C4AEFD77}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorGVD.dll HKCR\CLSID\{3E0E3B74-2DB8-4C79-AFDA-D3087C58BA3D}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{42E08053-47DA-415D-AB61-3501D60FBE33}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVidEnc.ax HKCR\CLSID\{44D0A5F0-A4B1-43CB-AAA6-FD7025A2D910}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVidEnc.ax HKCR\CLSID\{44D985D8-E0AF-44EB-959E-C50FB8C479DA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GRGL.ax HKCR\CLSID\{4814F96F-AA42-495B-B6CD-04502698DEED}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{49C53741-6362-47C9-90BE-CCB767141222}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{4E6BB33E-C046-496C-8322-E18D84A07190}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVidEnc.ax HKCR\CLSID\{504F9E47-A6CC-4D6B-8104-44670E7FA411}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVidFx.ax HKCR\CLSID\{53CAF9E4-0048-4CF5-A624-C11083C641C6}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVidEnc.ax HKCR\CLSID\{563A68F5-4DE9-4B4E-8389-BBD9D77745F8}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\Dispatch.dll HKCR\CLSID\{5918F857-05F7-4c84-A79E-75BCDFC7E34C}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAuNRWrapper.ax HKCR\CLSID\{5E479EF1-9BDB-42AA-B273-6004D83C9212}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{5F5C679F-4717-4B76-BFE4-D35059D0D00F}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{600168F9-0617-48ED-AC8A-E0839E9F97B4}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2Gm2spliter.ax HKCR\CLSID\{6263C176-0876-4B04-8DE0-44AB74489D72}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{65BF2C24-94ED-4305-BD81-D256F5B85656}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2Gauts.ax HKCR\CLSID\{65F3D6CA-CE8A-4F37-A74B-B1D13B8E1CBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVB.ax HKCR\CLSID\{66855507-19B6-45B0-A83A-78178247CADC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{6726EE38-BB56-4515-BE6A-50F2032AC822}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{6A549725-3828-41A5-B334-05A2DC5E5F71}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\DIEGO.dll HKCR\CLSID\{6B6BFA32-AF02-4CB9-A2A7-18CC1169907D}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GDumpDispatch.ax HKCR\CLSID\{6E0EED5F-4B78-455F-B688-073E3E5D1079}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{6F48159A-E44A-4240-9038-34F22C28B851}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAudEnc.ax HKCR\CLSID\{6FB831DC-69EF-49E1-A999-729CB4D74BA6}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAudEnc.ax HKCR\CLSID\{70F4F30D-C7A4-40E2-8BA0-EB8CBBFF6EE2}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{711DA875-8A14-4E25-8855-D327A09B7FA0}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAuRsmpl.ax HKCR\CLSID\{74DA3201-9816-42E9-88F6-8E0B72E639E0}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{7A4EDBA4-52C5-4714-ABB8-F0D2CF1B704F}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2Gm1spliter.ax HKCR\CLSID\{7D9070AB-371A-4614-A964-D21BDFE1030B}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorHMT.dll HKCR\CLSID\{7DF07DB9-682E-4BB2-8234-5E0AE7F7B97A}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{7F6654AC-EB9F-49FC-8FBD-7F7C43FD752B}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{8AD9C840-044E-11D1-B3E9-00805F499D93}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{8B198446-2059-43E1-BFF2-ED2A27D1DC40}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GReader.ax HKCR\CLSID\{8C56B364-6CD9-4907-B5C1-30A4B03D35B8}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVB.ax HKCR\CLSID\{8D2654EC-BAE2-43D6-B05A-AA1790C7B707}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GM2VWriter.ax HKCR\CLSID\{8D508C0D-E1C3-4C85-A7B6-7B5CD4392105}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVidEnc.ax HKCR\CLSID\{90D929DC-DF71-4834-B7B9-94CC2F4F4D57}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{9309523F-5023-45F6-ACFB-19658C54CB62}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GDump.ax HKCR\CLSID\{93D04A3E-1510-4FBF-9AAF-F1F09C3BC71E}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVideoStabilizer.ax HKCR\CLSID\{94F20D00-59CE-4FF7-BFB8-E6BF852AD4B0}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAudEnc.ax HKCR\CLSID\{9825E79B-A8AC-41CF-9532-1C3D9335CEEA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAudioCD.ax HKCR\CLSID\{9984EEFC-CA47-43BC-BDDE-AD55D74B9798}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GPCMEnc.ax HKCR\CLSID\{9B16BA00-C8B5-48F6-BF4A-DE3E5E587BF0}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{9B6A6AF3-D86A-4481-9523-1F4691E73FE1}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GDump.ax HKCR\CLSID\{9BC7E141-912D-11D3-B1AD-0080C84E9C15}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GMpgMux.ax HKCR\CLSID\{A1BA6800-D60E-11D2-8F3F-0080C84E9806}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorHMT.dll HKCR\CLSID\{A323B9F2-B3D0-4743-8A47-9155D569E140}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\Dispatch.dll HKCR\CLSID\{A39DDD3A-DCB5-4697-97AD-DD6695D99580}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{AC95627D-77B8-4A12-B496-1C479D0C38A9}
ActiveX/COM Issue InProcServer32\C:\Program Files\WinRAR\rarext32.dll HKCR\CLSID\{B41DB860-8EE4-11D2-9906-E49FADC173CA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVidEnc.ax HKCR\CLSID\{B61DA107-0EA9-45ED-94B1-22A1BA8F6CE8}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{BD38D27A-D83A-4DD3-AFEB-17F3F81D49A1}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{BDF6CAFA-A6DB-46EA-A887-951CABEF61A3}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GDVRS2MPG.dll HKCR\CLSID\{C20CE7A8-A212-42FF-9746-FDE7B77F3DBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{C675648D-695F-46DB-BC90-C8EA656CAB1E}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{C7F708B3-5E18-411C-9F23-14934ACA592D}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0000-0003-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0000-0004-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0000-0005-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0000-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0000-0000-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0000-0000-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0000-0001-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0000-0001-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0000-0002-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0000-0002-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0000-0003-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0000-0003-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0000-0004-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0000-0004-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0017-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0017-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0018-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0018-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0019-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0019-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0020-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0020-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0021-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0021-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0022-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0022-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0023-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0023-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0024-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0024-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0025-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0025-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0026-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0026-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0027-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0027-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0028-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0028-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0029-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0029-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0030-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-0030-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0014-0002-FFFF-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0023-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0023-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0023-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0024-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0024-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0024-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0025-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0025-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0025-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0026-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0026-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0026-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0027-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0027-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0027-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0028-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0028-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0028-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0029-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0029-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0029-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0030-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0030-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-0030-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0015-0000-FFFF-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0011-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0011-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0011-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0025-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0025-ABCDEFFEDCBB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-0025-ABCDEFFEDCBC}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{CAFEEFAC-0016-0000-FFFF-ABCDEFFEDCBA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2Gauts.ax HKCR\CLSID\{CC29DF71-ECDE-4C60-BCD7-7503557AAB54}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GTLMSplter.ax HKCR\CLSID\{CDCFDBB0-6518-4239-8085-A16AD63488AE}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GMpgMux.ax HKCR\CLSID\{CF6ED441-FC79-4F1A-9D91-4AE01C570B81}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GVSD.ax HKCR\CLSID\{D04DBF16-B41D-4BB4-AF84-F9A7523FDBB7}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorHMT.dll HKCR\CLSID\{D08352CE-EAD5-443E-9706-80C2200497CE}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\CyberLink\MediaShow\subsys\UACAgent\UACObject.dll HKCR\CLSID\{D5A8AF9D-75E6-40AF-8482-23F8439D57C1}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{D817DD53-1E0E-430C-9DC1-424F997CEC2A}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GDumpDispatch.ax HKCR\CLSID\{DAFED5E2-A2D7-11D5-8C16-0050BA17CEE2}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll HKCR\CLSID\{DBC80044-A445-435b-BC74-9C25C1C588A9}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAudEnc.ax HKCR\CLSID\{DDEAC24D-8E13-451E-8A82-51CDE9E8A6C6}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\CLImgUtility.dll HKCR\CLSID\{DFE8FFC0-EF47-4E08-B788-B7C8ED953AFA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Java\jre6\bin\jp2iexp.dll HKCR\CLSID\{E19F9331-3110-11D4-991C-005004D3B3DB}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GResample.ax HKCR\CLSID\{E5B455E5-098A-4B65-B2A8-871274FF51CE}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorHMT.dll HKCR\CLSID\{E7C9C66D-B247-4129-8823-22C6CFA72DA6}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAudEnc.ax HKCR\CLSID\{E8F36981-7D45-4AF4-ACA2-E7D960D5AD6F}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{EBF9CC5A-4694-4C04-933F-81807B9919EA}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GSEditor.dll HKCR\CLSID\{EC23CB4B-DEF6-4558-AC0A-303E4BEDF7A3}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorHMT.dll HKCR\CLSID\{ECA9C5CF-4EFD-4D8C-AF6B-D1F1A03D25C0}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\AuthorBAT.dll HKCR\CLSID\{ED467446-B827-4AE2-B2F9-20E855AEECC8}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GMediaLibrary.dll HKCR\CLSID\{F2B06184-F291-41bb-BB67-519FD608ED81}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GAud.ax HKCR\CLSID\{F3FC4166-FC54-4AE9-984B-E13610CD559A}
ActiveX/COM Issue InProcServer32\C:\Program Files (x86)\Cyberlink\Power2Go\P2GMVD.ax HKCR\CLSID\{FF1715E9-885B-47A8-8F76-16C44539309B}
ActiveX/COM Issue LocalServer32\C:\Windows\system32\igfxcfg.exe HKCR\CLSID\{A354BD60-4C0A-11d3-B561-00A0C92E6848}
ActiveX/COM Issue LocalServer32\C:\Windows\system32\igfxcfg.exe HKCR\CLSID\{EE2D6561-D63C-11D2-B561-00A0C92E6848}
Missing TypeLib Reference IFBControl - {2FA18656-2AA2-4EA7-9816-0B054FD71A5D} HKCR\Interface\{5680A854-2695-4265-97EC-C7B1306E9ECD}
Missing TypeLib Reference IFBComJavascriptObject - {2FA18656-2AA2-4EA7-9816-0B054FD71A5D} HKCR\Interface\{7CCA075B-16B3-4AF9-8F2D-7E8A02298E45}
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Menus HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Skin HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\OLRSubmission HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Ara HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Bgr HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Chs HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Cht HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Csy HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Dan HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Deu HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Ell HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Eng HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Enu HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Esp HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Eti HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Fin HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Fra HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Heb HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Hrv HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Hun HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Ita HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Jpn HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Kor HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Lth HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Lvi HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Nld HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Nor HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Plk HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Ptb HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Ptg HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Rom HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Rus HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Sky HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Slv HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Srl HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Sve HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\Cyberlink\Power2Go\Language\Trk HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\Custom HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\Promotion HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports\LayerTemplate HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Gems\LayerTemplate HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Gems HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Paintbrush\LayerTemplate HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Paintbrush HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Rose\LayerTemplate HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Rose HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Starfire\LayerTemplate HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Starfire HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Stargazer\LayerTemplate HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Stargazer HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\Custom\Setting HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\OLRSubmission HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Blackboard HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\E-Motion HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports\background HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports\frame HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports\highlight HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports\LayerTemplate\LayerTemplate1 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports\LayerTemplate\LayerTemplate2 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports\LayerTemplate\LayerTemplate3 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports\LayerTemplate\LayerTemplate4 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports\LayerTemplate\LayerTemplate5 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports\layout HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Extreme Sports\pcbg HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Gems\LayerTemplate\LayerTemplate1 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Gems\LayerTemplate\LayerTemplate2 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Gems\LayerTemplate\LayerTemplate3 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Gems\LayerTemplate\LayerTemplate4 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Gems\LayerTemplate\LayerTemplate5 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Gems\layout HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Noir HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Noir\background HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Paintbrush\background HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Paintbrush\LayerTemplate\LayerTemplate1 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Paintbrush\LayerTemplate\LayerTemplate2 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Paintbrush\LayerTemplate\LayerTemplate3 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Paintbrush\layout HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Retro Wedding HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Retro Wedding\background HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Rose\LayerTemplate\LayerTemplate1 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Rose\LayerTemplate\LayerTemplate2 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Rose\LayerTemplate\LayerTemplate3 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Rose\LayerTemplate\LayerTemplate4 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Rose\LayerTemplate\LayerTemplate5 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Rose\layout HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Starfire\LayerTemplate\LayerTemplate1 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Starfire\LayerTemplate\LayerTemplate2 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Starfire\LayerTemplate\LayerTemplate3 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Starfire\LayerTemplate\LayerTemplate4 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Starfire\LayerTemplate\LayerTemplate5 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Starfire\LayerTemplate\LayerTemplate6 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Starfire\layout HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Stargazer\background HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Stargazer\LayerTemplate\LayerTemplate1 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Stargazer\LayerTemplate\LayerTemplate2 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Stargazer\LayerTemplate\LayerTemplate3 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\Program Files (x86)\CyberLink\MediaShow\subsys\DVD\Menus\Stargazer\layout HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Invalid firewall rule TCP Query User{89F40FF6-893F-4D70-908E-E6D71B961E47}C:\program files (x86)\java\jre6\bin\java.exe - C:\program files (x86)\java\jre6\bin\java.exe HKLM\SYSTEM\ControlSet001\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules
Invalid firewall rule UDP Query User{14B5EA7A-88F4-4495-B1C1-A11FDC807B90}C:\program files (x86)\java\jre6\bin\java.exe - C:\program files (x86)\java\jre6\bin\java.exe HKLM\SYSTEM\ControlSet001\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules
Invalid firewall rule TCP Query User{89F40FF6-893F-4D70-908E-E6D71B961E47}C:\program files (x86)\java\jre6\bin\java.exe - C:\program files (x86)\java\jre6\bin\java.exe HKLM\SYSTEM\ControlSet002\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules
Invalid firewall rule UDP Query User{14B5EA7A-88F4-4495-B1C1-A11FDC807B90}C:\program files (x86)\java\jre6\bin\java.exe - C:\program files (x86)\java\jre6\bin\java.exe HKLM\SYSTEM\ControlSet002\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules
Invalid firewall rule TCP Query User{89F40FF6-893F-4D70-908E-E6D71B961E47}C:\program files (x86)\java\jre6\bin\java.exe - C:\program files (x86)\java\jre6\bin\java.exe HKLM\SYSTEM\ControlSet003\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules
Invalid firewall rule UDP Query User{14B5EA7A-88F4-4495-B1C1-A11FDC807B90}C:\program files (x86)\java\jre6\bin\java.exe - C:\program files (x86)\java\jre6\bin\java.exe HKLM\SYSTEM\ControlSet003\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules
Missing MUI Reference C:\program files (x86)\java\jre6\bin\java.exe HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache
Invalid file reference ImagePath - "c:\program files (x86)\hewlett-packard\hp health check\hphc_service.exe" HKLM\SYSTEM\CurrentControlSet\services\HP Health Check Service
Using tools like that can cause problems not just fix them. What I would do is backup, format, install and never use applications like this again.
Does CC cleaner fix your problem or is it still there?
Well they don't how up no more but these do
Unused File Extension .WLMP HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.WLMP
Invalid or empty file class BlankCD HKCR\BlankCD
Invalid or empty file class BlankDVD HKCR\BlankDVD
ActiveX/COM Issue CLMediaLibrary.MediaLibrary - {F2B06184-F291-41bb-BB67-519FD608ED81} HKCR\CLMediaLibrary.MediaLibrary
ActiveX/COM Issue CLMediaLibrary.MediaLibrary.1 - {F2B06184-F291-41bb-BB67-519FD608ED81} HKCR\CLMediaLibrary.MediaLibrary.1
ActiveX/COM Issue igfxcfg.DataObject - {A354BD60-4C0A-11d3-B561-00A0C92E6848} HKCR\igfxcfg.DataObject
ActiveX/COM Issue igfxcfg.DataObject.1 - {A354BD60-4C0A-11d3-B561-00A0C92E6848} HKCR\igfxcfg.DataObject.1
ActiveX/COM Issue igfxcfg.ShellExt - {EE2D6561-D63C-11D2-B561-00A0C92E6848} HKCR\igfxcfg.ShellExt
ActiveX/COM Issue igfxcfg.ShellExt.1 - {EE2D6561-D63C-11D2-B561-00A0C92E6848} HKCR\igfxcfg.ShellExt.1
ActiveX/COM Issue UACObject.UACAgent - {D5A8AF9D-75E6-40AF-8482-23F8439D57C1} HKCR\UACObject.UACAgent
ActiveX/COM Issue UACObject.UACAgent.1 - {D5A8AF9D-75E6-40AF-8482-23F8439D57C1} HKCR\UACObject.UACAgent.1
Installer Reference Issue C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Live HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
