Slow RAID SSD performance
23 Mar 2005
I have a pair of Samsung SSD (60ish GB) drives in my laptop and the performance has been degrading steadily over time. I now get:
They are pretty old drives, just pre-dating the trim updates (can't remember the model number) but the write performance was considerably better when I first installed them. I have about 30GB of 120GB let free. Is there any good garbage collection software I can run on a one-off basis to breathe some life back into them? I don't really want to go through the pain of imaging the drives and reformatting etc...
Raiding SSD disables trim, which means theyll get slower and slower over time. If they dont support trim then all i can think of is dumping the contents to some other storage and erasing them before putting back the data.
They are pretty old drives, just pre-dating the trim updates ...snip.... Is there any good garbage collection software I can run on a one-off basis to breathe some life back into them? I don't really want to go through the pain of imaging the drives and reformatting etc...
The drives don't support trim (even individually) - all I really need is a piece of software that does garbage collection on the empty space. There must be something out there by now that does it?
I've not seen anything that does what you ask in RAID I'm afraid, esp for Samsung drives!
Quick and easiest is to clone the drives, wipe the array, run whatever cleaning software you have and then copy it back.
When I was running my 160Gb Intel without trim the process took about 2 hours to copy everything off, wipe it, and copy it back.
Just a thought - I noticed CCleaner has a "Wipe Free Space" option that does exactly what I was talking about - effectively overwriting all the empty space on the drive - would this not achieve the same goal as the standard garbage collectors?
Worth a try then complete a read/write speed test to compare against previous results? It wont take hours.
SSD performs best when the NAND hasn't been touched (as in, ever written to).
The only way to get it back to that stage is to Secure Erase the drive (or TRIM those areas). Wiping free space (where TRIM isn't working) will do more harm than good.
So the best thing you can do is take an image, break the RAID, SE each drive, recreate the RAID and then put the image back.
Raiding SSD disables trim, which means theyll get slower and slower over time. If they dont support trim.
According to research certain ssd's are ideal for raid and have very aggressive garbage collection or Idle Time Garbage Collection (ITGC), which apparently work in a similar fashion to TRIM and helps ensure top performancce levels. Apparently turning off write cache buffer flushing improves certain transfer speeds but research yourselves before committing tests/benchmarks.
What's the source for this? Seems counter-intuitive. (A bit that reads zero, reads zero irrespective of how it got there?)
I will run the wipe overnight and see what happens - will be interesting to see.
If it's doing what I think it is doing then it will slow things down.
The SSD keeps track of where the data is, and if there is NAND that it KNOWS is free then it can write at full speed.
Writing zeros to it makes it thinks that space is USED and hence has to wipe it before writing to it.
Secure erasing is the ONLY way to improve SSD performance without trim, and you have to break your array for that.
RAID has always been more effort than it's worth in my mind.
