Can you run heaven at the same settings as me mate?
Cheers
.What he doesn't say is that he went through EVGAs stock and cherry picked it.
(would have been flashed to F T W < = bad word?)Might not be for a while. I don't like to bench the htpc system too often![]()
Its only running Heaven
If its in a HTPC why the high clocks?![]()
I thought this was an overclocking thread?
I don't like OC the GPU for a daily user, stock clocks is good for me!
Found how to change the voltage, Using nVidia inspector is key.
Currently 900/1800/2040 at 1.0v I'll see if I can get any more out of it later, how much is the maximum safe voltage?
Not sure why, but I guess min and max speeds are just a "one-off" occurance during each benchmark. Perhaps it is the slight architectual differences between the cards, driver optimistaions (400 vs 500 series) or general general differences. Overall performance is pretty much equal with my min fps being higher, but max fps lower. I am sure it would be near impossible to tell the difference between the cards in gaming terms, although your 570 will run noticably quieter at stock settings than my 480.Nice score aswell. Your max FPS seems low compared to mine, how does that work ??
[TW]Fox;19921726 said:You have a 570 now easy? I'm sure I remember you as a big time advocate of the ATi cards back when I got my 570 6 months ago![]()
Up the vcore. I bet you are having mem errors when running
