Two machines identical..apart from one being 32-bit Win7 and the other 64-bit Win7 Both Dell laptops.. But identical hardware wise.
One machine has a memory operatings per sec @ 5.9 (the 64-bit one)
and the other has it at 7.5 (32-bit?)
I'm scratching my head as to why.... Both brand new machines..
Just curious.
 This is exactly the reason I am getting this on one 64-bit machine and not the other.. Its because this particular laptop has a new i7 2620m, which works alongside the new shared Intel HD 3000 gfx. Which is shares processing with the CPU and shares memory with the memory  !!! Therefore it's taking away from the 4gig, and as you can see from the code, WEI is specifically limiting to 5.9.  Problem would be fixed if I had 4gig, but 1meg below and boom, you're stuck to 5.9   only on score mind..  Anway, at least I now have the answer..
