Who here owns a Renaultsport?
Finally got my service done, Renault confirmed a smaller service was fine after looking through all of my receipts from previous work. A few things they advised me on, some of which I knew, but nothing major fortunately.
Only cost £139 so I was quite chuffed. I haven't actually checked everything they did, and frankly I can't be bothered.
I drove a new shaped normal Clio as a courtesy car today, it felt like getting into a racing car when I got in my 182 again! haha. I also NEVER knew that you could lower the seats in the 182, I accidentally discovered that today :o
Really? I have brembo disks, ds2500 pads and braided lines and I'm sure it came to about £270 for the fronts. Will have to check with Benny
Paid around £300 for the lines, DS2500's fronts, Brembo HC's, standard rear pads, Fluid & bleed kit. Did the rear discs a few months later for £100 with bearings via JMS.
Rear DS2500's are around £80/90 from memory.
As for the mileage it depends how you drive. The occasional hoon and I probably only used about 60 or 70% of what was on offer and after around 5k miles they hadn't really looked touched. Though I used to engine brake a lot.
My seats are lower than normal and its much better. Did have to lower the steering column too though as it felt like I was hanging from it.
My seat is in its lowest and furthest back setting, and lowered more by removing the vibration washers under it, and the steering wheel is up high.
I am 6'4" though...
