What 1200W power supply
Do you really need 1200w?
Don't mind me if you do, but a lot of people don't understand the basic power consumption on computers, and in a lot of cases, some high end PC's only pull up to around 400w. it's only with 2-3 high end gpus that 1200w is needed.
like i said though, if you do need it, sorry, just pointing out. :)
How about bequiet?
just seen you have "2x gtx 460 1 ssd 1 hdd haf x case mobo p8p67 deluxe i7 2600k"
i'm sure that would perform better with a lower wattage psu (to get the best efficiency)
a good 750-800w should suffice.
How about bequiet?
Going to upgrade soon to like 2x 580 sli
One of the reviewers for the BeQuiet states that BeQuiet now have UK support.
No OcUK reviews on the Antec.
Firstly I hope you are not going off the random comments of some random person instead of a tried and tested review site?
Secondly Bequiet RMA goto German or Netherlands, cant remember which but its £30 either way to send a heavy PSU.
If it's for 2x 580's then u don't need a 1200w psu, so this would do.
Or if u wanted headroom any decent 1000w is plenty.
The price range u have is not really enough for a decent quality 1200w other than the "king of coil whine" ZX 1250w :P
