- 10 Nov 2009
- Sweden
Like the title says, also i dont want any corsair brand as i hate tyem the reason Well look on my started topics and you will see
Going to upgrade soon to like 2x 580 sliDo you really need 1200w?
Don't mind me if you do, but a lot of people don't understand the basic power consumption on computers, and in a lot of cases, some high end PC's only pull up to around 400w. it's only with 2-3 high end gpus that 1200w is needed.
like i said though, if you do need it, sorry, just pointing out.
How about bequiet?
just seen you have "2x gtx 460 1 ssd 1 hdd haf x case mobo p8p67 deluxe i7 2600k"
i'm sure that would perform better with a lower wattage psu (to get the best efficiency)
a good 750-800w should suffice.
That psu makes high noise on high load jonny guru said that in hes review and some other reviews said the same
It needs to be in the same price range as the ocz
One of the reviewers for the BeQuiet states that BeQuiet now have UK support.
No OcUK reviews on the Antec.
Another non Corsair option is Antec High Current Pro 1200W Modular '80 Plus Gold' Power Supply [0-761345-06255-8] at £229.99.
The Antec has a 5 year warranty, whereas the BeQuiet only carries a 3 year warranty.
Antec cost to much and am from sweden
Find one of these - http://www.coolermaster.com/product.php?product_id=6663
If it's for 2x 580's then u don't need a 1200w psu, so this would do.
Or if u wanted headroom any decent 1000w is plenty.
The price range u have is not really enough for a decent quality 1200w.
