 - 24 Sep 2008
 - St. Neots, cambs
Hello again, This project is a rebuild of my current colossus build.  I have removed the hard drive tray so I can fit another 240mm rad at the bottom to go with the 240 rad at the top.  I have also purchased a new res. I am also changing the colour scheme but i will keep that part a secret for the time being!. So here comes the pictures of what i have done so far.
Here is the bare chassis with the hard drive tray removed. It makes the case look even bigger I think.
I had to drill a couple of holes in the front of the case so i could fix the rad to the front with the radiator grill.
Side shot, perfect fit
New res, gpu backplate and cpu block fitted. I think the res is a thing of beauty!
Closer look at the gpu and xspc rasa cpu block
Pump mounted
Picture of how things stand at the moment.
I already have the tubing and fluid purchased (colour to be revealed later). I am just waiting on my new radiator to arrive tommorow then I will have all the gear i need. I think i am going to buy some new compression fittings, i currently have the black dark nickle xspc fittings but they are not dark enough. So i think i am going to buy some of the matt black EK fittings and sell the ones i currently have.
Hope you like the look of the project so far.
Tony
	Pump mounted
Tony
