But it makes high sound so no
Well actually Jonnyguru never tested the 1250W version.
And by the time something is suggested you come back saying it costs too much. Its difficult to suggest something for someone living in a different part of the world.
Can pay 1800 check prisjakt.nu it finds the cheapest in sweden
Have a question the hale seems good but its not fully modular. And is 1000w enuf for overclocking and future x2 sli/cf setups? And will the cables be long enuf? My last psu was corsair ax850
Having fully modular is stupid, you must use a 24pin ATX and 8pin ATX and a few SATA etc
The cable lengths are here in the specs - http://www.nzxt.com/new/products/power_supplies/hale90_1000w
1000W is good enough for SLI GTX580 - http://www.guru3d.com/article/geforce-gtx-580-sli-review/14
That psu makes high noise on high load jonny guru said that in hes review and some other reviews said the same
And The hale 1000w sry am on my phone
Used a the eXtreme Power Supply Calculator it says i need 1182w wtf???
• ATX / BTX motherboard power connector (20+4Pin) 550mm
• +12V Power Connector (4+4 Pin) 550mm
• Peripheral connector (4 Pin) 550mm
In fact they are all 550mm long
