What 1200W power supply
Bump
Bump 2
Hi can you please stop bumping this thread, when so little time has passed.
Waiting less than 30 mins, and then bumping will only annoy people :)
With the money you have.
I would look at a seasonic and then cross fire 6970's
Have we moved away from the idea of dual-psu solutions now? I always thought it was a great way to keep costs down if you had the space in your case? Is that worth considering any more?
Totally not needed, any single high quality 80+ gold psu is plenty for what the OP is asking to power.
The point is that it is significantly cheaper to get 1200W with 2x600W PSUs that it is in a single unit - if you are tight on cash - consider buying 2 lower powered, high quality PSUs instead of one almightly unit. ;)
With the headroom he was looking for 1000W+ seems to be the sweet spot.
Bump
Bump 2
Sry yeah will see if inet.se have this psu btw in my other thread they said wait for the new ati series is that still a good idea?
Well no point in looking at psu's now if you have sold GPU's.
You need to look at what GPU's you are getting then look at the psu.
If you go CF OR sli. 850w is possible. But go higher on the cards and you may need 1000w
But you are talking about next gen cards now. 1250W may not be enough.
Considering the fact that the next gen GPUs will be made at a smaller process, and not wanting to repeat the abortion that was Fermi, I would expect the next gen cards to consume less power.
Maybe, but OP could waste a a lot of money with not a lot of headroom. So he needs to work out what cards he wants first.
Well 2 gtx 590 uses 819w with the whole system but i think 1200w is overkill thats why i want them and am only doing sli or cf nothing more and 1200w should be enuf for the future.
Ps... Not saying that i will go for 2 590 just pointing out that if 2 gtx 590 only use 819w then i guess 1200 will be enuf
