6950 faulty?
1 Aug 2011
bought a His 2gb 6950 on the 26th, plays games great and runs cool however i have noticed in one or two game, bc2 makes a odd whiney noise once or twice, only noticed as i had headphones off which i game with and in the menu in killing floor(only in menu not while maps are running) it makes a noise like an old school 56k modem dialing out lol any one else experience this?
try enabling v-sync it can cure the coil whine which is often caused by super high frame rates (thus affects menus mostly).
psu should be fine, its a thermaltake 650 w few years old but run mmy system fine. will be upgrading at end of month cos im going xfire but it only has 2 6pin pcie cables, could use molex to 6 pin adapters but i dont think its worth the risk,will try the v sync but when its only menus its not a massive drama
If your 650w is a good quality PSU you won't have to upgrade your PSU as i'm going to crossfire with 6950's with a 650W PSU. The molex to 6 pin adapters will be fine :D
Its strange there have been a few threads lately about whiney cards, just put mine in today and it makes a whine but strangely enough when i'm browsing, once I actually put the gpu to use gaming or whatever it stops, it also changes pitch slightly when scrolling lol.
Its very quiet though and no louder than a hard drive spinning.
yes exactly like this. as for the molex to 6 pin it needs 2 to power 1 6pin. i have 2 railsfree but they have 3 molex per rail(dont know if thats right way to put it) do the molex have to go from the seperate rails?
