The SFF Case Gallery And Specs Thread
Here's a few pics, probably too many, of my recent Silverstone SG02F/Llano build.
It was designed as a general purpose family PC that could do time as a HTPC if needed (hopefully it'll last 10+ years too)
Specs:
AMD Llano A8-3850 @ 2.9GHz.
MSI A75MA-G55.
1TB SATA Drive.
6GB DDR3 @ 1600MHz (1-2GB dedicated to GPU)
Corsair CX 430W.
Silverstone SG02F.
I need shorter SATA cables, luckily the extra PSU cables can be stashed up top.
Decent 80mm HDD cage fan. Far too noisy at stock though, reducing it to ~1000rpm does the job.
4 USB 3.0 ports!
The stock cooler isn't too bad, you can tone it down to 1000-1500rpm without issues.
Sustained CPU/GPU activity above 50% brings it up to a 3000rpm.
Pow! A super mutant gets one in the kisser. :cool: Gaming at 1920*1200 (with highish settings) using a IGP! :)
Compared to a SG33G5M DELUXE.
couple of mods to the box, gelid 92mm pushing from inside and artic 92mm pulling from outside and bitfenix spectre 120mm Fan on top pulling air out.
all very quiet:D
thought i would join the sff crew!!
spec is.
2500 i5
G.Skill RipJawsX 8gb
Ati 6950
Crucial C300
500gb back up hdd
external dvd-rw
What PSU are you running mate? Does it work fine on the standard 300 or did you have to get the uprated 500w?
My lovely new case - same ole specs, just changed from a V354 to this lovely looking PC-C50 o and a Corsair H100 replacing my TRUE120 - hence the fans outside the case.
scaled.php
OMG someone actually bought 1!!!! :eek: How much did it cost and where are all the cables or do you just like the look of it and not turn it on? :D
second hand from usa 50$ (shipping to EU was 25$)
so 2/3 price of the new one locally ;)
when I was making this pic PC was completed (excluding RAM only)
ssd under mobo, + pico psu 150XT
nipped up to oc monday and bought a shuttle
happy with it so far, removed the shuttle cpu fan shroud so fan directly on fins and going to update the 92mm fan, apart from that tis all good!:D
spec is.
2500 i5
Ati 6950
Crucial C300
500gb back up hdd
external dvd-rw
Just curious any reason your selling your shuttle barebone on the flea bay?
Item No. 190574607982
Was looking at getting one myself thats all, was wondering if you had any issues with it. ;)
selling up, sold most of my gear on there.
i have a spare pc to use
no issues at all, solid as a rock
Heres a few parts im using for a new SFF machine im building mainly for MKV HD, Bluray and DVD playback. Going for the Asus E351M Deluxe ITX board with the AMD Hudson M1 GPU/CPU chip.
So far I have,
2x4GB 1333Mhz Ripjaws
Compucase SK01
Slimline Sata Drive cable
On Order
Asus E35M1-I Deluxe Board
OCZ Onyx 32GB SSD
3TB WD RE-GP Storage Drive
Logitech diNovo Mini Keyboard
Sony BC-5640H Sliline Slotload Bluray/DVDRW Combo
Oh and the Mrs is building it all without help from me :( pics of building in process and possible fails will be posted lol
:D
