main issue is too much wiring involved. Whilst I don't mind that, I don't want the clutter that follows it!
i really want to get that phobya 500cm strip - but it's £120![]()
I think your entitled to a replacement and if they throw anything extra then take that as a bonus
I used a breadboard for mine, so it only needed the two wires for the + and -. £120 is incredibly steep for that!
Nice case: How much does it set you back and where can i get one?
Thanks, I made it myself
I'll sell it for a tenner?![]()
i jusat looked inside a big box i have on top of the wardrobe and found a brand new one in it.. very posh![]()
I'll look into that - thankyou
It has 600 LED's
The annoying thing is that the same one, in blue is half the price![]()
Hi all,
I have two Phobya 60cm UV LED strips. A few days ago, I opened them both and one of them immediately started sparking once it was connected to the PSU and turned on.
I don't know the LED strips he has specifically, but I don't think LED strips need or have those controller boxes that cathode lights have, they can work straight off the voltages the molexes supply with a suitable resistor.
