- 7 Nov 2004
- Southampton/Oxford
I'll start from the er start..so with my host TSOhost, made a subdomain for blog use and so I could use a CMS so I could self teach my self CMS software, using 'Softalicious' to install WP, I tried to change the themes around but none of them are showing up the images let alone the theme correctly and have come to the conclusion I might have install the WP CMS in the wrong directory, being a noob and no simple guide unless I search for ages.
Could installing in a 'wrong' directory be an issue?
Example if I'm not making sense:
mydomain.com is my main
made a subdomain as: blog.mydomain.com
Which somehow created a new folder on my server "blog"
In which I created a folder called "dir" while installing a WP.
Now should I leave it there or drag the "dir" folder to the "www" folder instead? I'm lost here
Your not going to tell us the URL then?
The icons / Webpage is meant to load properly. Theres still something wrong.
